The recalbox-wpaf utility allows you to control certain cards (hat) that have a fan.
The list of cards supported by recalbox-wpaf is available here.
Configuration is done in the recalbox.conf file under the hat.wpaf.enabled and hat.wpaf.board keys.
hat.wpaf.enabledSet this key to 1 to enable the recalbox-wpaf utility.
hat.wpaf.boardThis key allows you to select the board that powers your Raspberry PI. Possible values are:
wspoehatb for the Waveshare PoE hat board (b),argonforty for the card that powers the Argon One box,piboy for the Experimental PI box,rpipoeplus for the Raspberry PI PoE+ board,fanshim for the Pimoroni fan SHIM board.Example:
hat.wpaf.enabled=1
hat.wpaf.board=rpipoeplus
Reboot to take the settings into account.
