The Netplay lobby is a place where you can connect to play online with others. There are 2 ways to enjoy it:
You can join an online game either as a player or as a spectator (streaming).
By default, netplay is not enabled. To enable and customize it, in the system list, do Start > Game Options > Netplay Options.
The options are as follows:
NETPLAY : enables netplaySURNAME : your nickname on the netplayDo not use accented characters, this will prevent you from using netplay.
PORT : the port to use to connect to. Default is 55435.If you have an IP address with only certain ports range, you need to change the port here to what you can use and create a port redirect into your internet box.
Once you have filled those informations, you are ready to try an online game.
X button while being that the desired game.
Here are the options:
SET PLAYER PASSWORD : select ON if you want to put a player password on your game.
SET VIEVER PASSWORD: select ON if you want to set a spectator password on your game.
CHOOSE PLAYER PASSWORD : a selection of predefined passwords.
CHOOSE VIEWER-ONLY PASSWORD: a selection of predefined passwords.
Once you have made your choice:
START to start the game.
X in the system list. If Kodi is enabled, you will have a menu to choose the Netplay lobby.
For each game, you will have information:
Username : player name of the hostCountry : country code of your hostROM hash : match the rom signatureROM file - rom file matchCore : emulator usedCore Ver. : version of the emulatorLatency : response timeRA Ver. : version of RetroArchHost arch. : architecture of the host (you can have the Recalbox logo here if the host uses it)You will see the result in front of each item in the list, ✅ (valid) or ❌ (not valid).
You will see the global result at the bottom of the window on the right, indicating the chances of a successful connection:
