English version available here
Relive the unique feeling of retro consoles: insert a card into your Recalbox to launch the game of your choice!
The Card Reader and RecalCards transform your Recalbox into a real cartridge console, easy to use and fully plug and play.
Recalbox 10 will be needed for the functioning of the Card Reader.
Proceed with the installation of Recalbox 10 for Raspberry Pi 5 using the following link:
https://www.recalbox.com/download/stable/rpi/rpi5_64/
The Card Reader will allow you to:
When you insert a card for the first time, a popup will appear explaining that you need to associate the card with one of your games in Recalbox.
From the Recalbox menu, press START on a game to associate it with a card.
You can associate two games per card, one for the front and one for the back.
If you want to change the game associated with a card, simply insert the card into the reader, exit the game with the controller (HOTKEY + START), and associate a new one with the START menu.
If you ordered your Card Reader as an add-on, you already have your RecalTower.
To mount your Card Reader floor on your RecalTower, simply:
-Place the 4 nuts in the slots provided for this purpose.
-Stack the Card Reader floor onto your RecalTower and use the countersunk screws provided to secure everything in place.
Version without RGB DUAL 2:
Version with RGB DUAL 2:
Start Recalbox, and the system will automatically detect and install the Card Reader!
With Recalbox, you can enable Console mode in the RecalCards options. This mode allows you to activate a home screen, instead of the usual Recalbox menu, where you can run only the games linked to your RecalCards.
To enable Console mode on your Recalbox, access the Recalbox menu by pressing START, then go to “RecalCards settings”
Into this menu, you can:
HOTKEY + START or holding down the START button for 5 seconds)Once Console mode is enabled, restart Recalbox to access it.
Console mode looks like this :
In order for the game to run, at least one controller must be connected to your Recalbox beforehand.
All you have to do is insert a RecalCard and play!
You received your RecalCards and want to do more than just write the name of the game on the stickers? Want to stick the logos of your favorite games on them?
A label generator is available via the following link: https://recalcards-gen.recalbox.com/
Here are the steps for using it:
For any questions/suggestions, or sharing your custom label designs for your RecalCards, the #card-reader channel is accessible via our Discord server. (Access link).
Allow Boot On Game feature in RecalCards settings (START -> RECALCARDS SETTINGS)
