To obtain a quality audio signal on the Pi, one solution is to use a HiFiBerry DAC (Digital - Analog Converter).
These DAC exist in several versions:
The specifications of the different cards can be compared on hifiberry.com.
The DAC+ cards can be connected directly to the GPIO of the Pi. Pins not used by the DAC can be reused for other purposes, in which case additional pins must be soldered to the DAC+ board.
Below is the wiring diagram of a HifiBerry DAC+: hifiberry
The version for Raspberry A and B must be installed on pin 5.
Once the board is installed, there are a few more software configuration steps to get everything working
dtoverlay=hifiberry-dacdtoverlay=hifiberry-dacplus * In the same file, add the followingforce_eeprom_read=0./etc/asound.conf (create it if it does not exist) with the following content:
pcm.!default { type hw card 0 } ctl.!default { type hw card 0 }Now you should hear sound from your HiFiBerry card.
You cannot change the sound volume in EmulationStation only by Alsamixer / Amixer.
ALSA sound cards (and this is the case of HiFiBerry) can be controlled by Alsamixer.
Alsamixer is a graphical interface, while Amixer works in text mode, especially for scripts.
Since alsa-utils is installed on Recalbox, HifiBerry will work without additional utilities.
The DAC+ Light and the old DAC have no settings possible in ALSA.
With the command amix you will have a text version of the different DAC settings.
The best way to change the volume is to change the "Overall volume". Its name may differ depending on the card: 'PCM', 'Digital', 'Master', it's up to you.
The following commands allow you to change the volume through the terminal:
amixer sset 'Master' -- 90% (not recommended because the scale is logarithmic)amixer sset 'Master' -- -3dB (in decibels, recommended setting)amixer sset 'Master' - 2000 (empirical unit, not recommended)You can use Google to discover the rest of the possible commands with the keywords: amixer, alsamixer.
Here is an example in python to handle the volume.
First, import the subprocess command :
from subprocess import call
call(["amixer", "sset", "Digital", "--", str(YourDesiredVolume)+"dB"])
This script can be used to change the volume by using the GPIO.
Here is a summary of some commands:
amixer sset 'PCM' 70% (percentage)amixer sset 'Master' 3dB (Decibel)amixer sset 'Mic' 4 (material values)amixer sset 'PCM' 10%+ (increase of current value. Unit can be % or dB)amixer sset 'Line' cap (Recording on/off: cap, nocap)amixer sset 'Mic' mute (Playback on/off: mute, unmute)amixer sset 'Master' off (On/Off: on/off)amixer sset 'Mic Select' 'Mic1' (Device name)Source: https://wiki.ubuntuusers.de/amixer/
