With MAME, it is possible to add cheat codes.
It's best to use a controller with separate
SelectandHotkeybuttons if you want to keep the use of save states.
If you can't find the current version of MAME, download the first previous version and it will work at 100%.
cheat.7z.cheat.7z file in the /recalbox/share/bios/mame directory without uncompressing it! and run your game.To access the cheat codes during the game:
Hotkey + B.Core Options > System.
Cheats and exit the game.
Select + Y and go to Cheat.
