You can use an NVMe device with Recalbox to store your roms via an M.2 hat. This device will behave like an internal hard disk.
You must have your NVMe media formatted in exFAT. No formatting will done from Recalbox.
There are several brands of M.2 hat, some of them only accept a single NVMe and others can accept 2. This tutorial is based on an M.2 hat that accepts 2 NVMe medias but has only one NVMe connected.
This tutorial is mainly for the Raspberry Pi 5 and may be suitable for PC hard drives.
Follow the steps below and you will be able to use your NVMe as an additional roms storage media.
First of all, you need to update the bootloader of your Raspberry Pi 5 following this tutorial
The PCI Express 3 standard is compatible with the Raspberry Pi 5, and allows double read/write speed on compatible NVMe devices.
However, you need to activate it manually. To do this, go to the recalbox-user-config.txt file on the RECALBOX partition or using the SSH command vi /boot/recalbox-user-config.txt
Add the following line to the beginning of the file:
dtparam=pciex1_gen=3
You need to create a folder in your share to access the contents of your NVMe. To do this, use the following SSH command:
mkdir -p /recalbox/share/externals/hdd0
recalbox-boot.conf fileYou need to add a line to the recalbox-boot.conf file in 2 different ways:
In the drive named RECALBOX, open the recalbox-boot.conf file and add the following line on any empty line:
sharenetwork_cmd=mount /dev/nvme0n1p2 /recalbox/share/externals/hdd0
/boot/recalbox-boot.conf file and add the following line to any empty line:sharenetwork_cmd=mount /dev/nvme0n1p2 /recalbox/share/externals/hdd0
smb.conf fileHere, you need to modify the /etc/samba/smb.conf file from your switched-on Recalbox:
/etc/samba/smb.conf file and add the following lines at the end of the file:[nvme]
comment = Recalbox user data
path = /recalbox/share/externals/hdd0
writeable = yes
guest ok = yes
create mask = 0644
directory mask = 0755
force user = root
veto files = /._*/.DS_Store/
delete veto files = yes
Start or restart your Recalbox and look at:
nvme folder in the network shareSTART > SYSTEM SETTINGS > STORAGE MEDIA)mount command, your NVMe should appear:# mount
/dev/nvme0n1p2 on /recalbox/share/externals/hdd0 type exfat (rw,relatime,fmask=0022,dmark=0022,iocharset=utf8,errors=remount-ro)
If your NVMe is not displayed, you can check the name of your internal NVMe with this SSH command:
blkid
The result should look something like this:
/dev/nvme0n1p1: LABEL="EFI" UUID="67E3-17ED" TYPE="vfat"
/dev/nvme0n1p2: LABEL="NVMe 256G" UUID="66E9-99AE" TYPE="exfat"
/dev/mmcblk0p1: LABEL="RECALBOX" UUID="2A19-621E" TYPE="vfat"
/dev/mmcblk0p2: LABEL="SHARE" UUID="4140-70D7" TYPE="exfat"
/dev/mmcblk0p3: LABEL="OVERLAY" UUID="007f6e1f-ef13-4abd-9a69-1b70d8317e3b" TYPE="ext4"
Here, nvme0n1p1 is a small partition which can be created by some operating systems which is totally useless and too small for us, hence the use of nvme0n1p2 in the rest of the tutorial.
You can make your NVMe read-only if you don't want Recalbox to modify the files with this SSH command:
mount -o ro /dev/<your_nvme> /recalbox/share/externals/hdd0
It is very much not recommended to have your NVMe formatted in NTFS. If, however, you wish to have your NVMe usable in NTFS, it is VERY STRONGLY recommended that you mount them in read-only mode. The NTFS format is unfortunately not yet well supported with a Linux environment such as Recalbox, which may prevent you from being able to use your NVMe to write data to it.
