After installation, the first thing to do is to connect your box with Recalbox to your TV via the HDMI cable. To power and start your Recalbox, simply plug in the micro USB or USB-C power cable.
Many controllers work directly when you first use Recalbox. However, if you want to configure a USB controller directly, connect a USB keyboard, ... please see the Configuring a controller section.
On the system selection screen, press START. Choose SYSTEM SETTINGS > LANGUAGE, select your language and go back. Recalbox will tell you that it must restart. Once it has finished booting up, the menus will be completely in your language.
On the system selection screen, press SELECT and choose SHUTDOWN SYSTEM. Wait until the Pi's green/orange LED stops flashing so as not to damage the microSD card, and once it stops flashing, unplug the power cable.
Recalbox comes with a few royalty free games (homebrew) and/or demos for several systems.
You can add USB controllers to Recalbox. Most models are compatible (see the compatibility list).
After connecting your USB controller (or pairing your Bluetooth controller), press START with a previously configured controller. Select CONTROLLER SETTINGS and follow the instructions.
Select CONFIGURE A CONTROLLER and follow the instructions.
Press a key to start the configuration.
Hold down any button on the controller to configure it.
Now you can assign buttons to your controller. The names used to assign the buttons are those of the Super Nintendo controller:
The L1, R1, L2, R2, L3 and R3 buttons are based on the Playstation controller.
HOTKEY
The last button to configure, HOTKEY, is the one that will be used to activate the special-commands when you are in an emulator:
For Xbox 360 and Xbox One controllers, the Hotkey button is assigned to the
HOMEbutton.
For PS3 and PS4 controllers, the Hotkey button is assigned to thePSbutton.If there is no dedicated button or one has not yet been assigned, it is recommended that you assign Hotkey to the
Selectbutton.
To skip any button (except Hotkey), press the
Downkey to move to the next button.
For 6-button controllers (SNES, arcade, ...), the buttons are assigned in correspondence with the SNES controller (see above).
For 2-button controllers (NES, PC Engine, Gameboy, ...), the assigned buttons areAandB.
INPUT P1 to assign a controller.
If you can't configure your controller, you can connect a wired USB keyboard to your Recalbox to configure it. You can find all the key combinations of the keyboard here.
To link a PS3 controller:
Note:
For Asian copies of PS3 Dualshock 3 (like GASIA or SHANWAN), you will need to adjust some settings.
Warning :
If you have any doubts about the power supply and power consumption, it is better to avoid loading the PS3 controller on the Raspberry Pi because it can cause stability problems.Please connect the controller to the Raspberry Pi only to associate your controller with your Recalbox.
If you understand the settings involved or want to use your controller with a USB connection, you need to disable the PS3 bluetooth driver in recalbox.conf by finding and editing the line controllers.ps3.enabled=0.
Remember that the controller configuration in Recalbox is based on the SNES button configuration:
| PS3 controller | SNES controller |
| X | B |
| ◯ | A |
| ⬜ | Y |
| △ | X |
Information:
By default, HOTKEY is associated with the PS button (the one in the middle of the joystick).
For more information on HOTKEY, see the special-commands page.
Note:
Xbox 360 wireless controllers need a specific wireless receiver dongle.
| Xbox 360 Controller | SNES Controller |
| A | B |
| B | A |
| X | Y |
| Y | X |
Information :
By default, HOTKEY is associated with the HOME button (the one in the middle of the joystick).
To add a Bluetooth controller:
START and choose CONTROLLER SETTINGS.PAIR A BLUETOOTH CONTROLLER.A list of detected handsets appears!
Information:
For 8bitdo controllers, please see the 8bitdo on Recalbox page.
You can connect your arcade buttons and joysticks directly to the Raspberry Pi's GPIOs (see the page GPI controllers). You can also connect original controllers from PSOne, Nes, Snes, Megradrive, ... (see DB9 controllers and Gamecon controllers).
Virtuals controllers are not accessible on Raspberry Pi0 et Pi1 by default.
With the Miroof Virtual Gamepads project, you can add up to 4 controllers with your smartphones/tablets !
To do this, start your smartphone's web browser and type the IP address of your Recalbox followed by the communication port (port :8080).
Information:
You can find the IP address of your Recalbox in theNETWORK OPTIONSmenu.
Information:
You can very easily use a USB storage device (USB key, external self-powered hard drive etc.) to store your roms, personal files etc...With this method, the system (on the SD card) and the share partition (on the device) are separated.
So if you were to reinstall your system, you would keep all your user data.
All you have to do then is connect your device to your Recalbox, then select it in the system, and play.
First, you must use a device that uses the following file system: FAT32, EXFAT, EXT4 or NTFS.
Note:
It is highly recommended to use the EXFAT file system.
Caution:
Transfer rates can be slow** in the case of NTFS.
Also be sure that the file system you choose is compatible with your PC's operating system.
| Formats | Maximum Volume Size | Maximum File Size | Maximum Number of Files | Read/Write Mode |
| Fat | 2Tio | 4Gio (4.2949GB) | Greater than 250 million | Windows: ✅ Linux: ✅ |
| NTFS | 256Tb (2,815.8492TB) | 16Tb (17.5921TB) | 4,294,967,295 | Windows: ✅ Linux: ✅ |
| exFAT | 128Pio (144,115,1880TB) | 128Pio (144,115,1880TB) | 2,796,202 per directory | Windows: ✅ Linux: ✅ |
| Ext4 | 1 Eio (1,152,921.5046TB - limited to 16Tio per e2fsprogs) | 16Tio (17,5921TB) | 4 billion | Windows : ❌ Read/Write via ext2fsd Linux : ✅ |
Caution
Recalbox will not format your device, it will only create new files on it.
To configure Recalbox to use an additional USB storage device.
INITIALIZE.What to do if after reboot, Recalbox still does not see the hard disk?
Information:
Sometimes, after selecting the device in EmulationStation and rebooting, Recalbox fails to create the file system on it. It continues to use the files on the SD card. This happens especially with some hard drives that are slow to initialize.
What you can do:
cd /boot and nano recalbox-boot.conf.sharewait=30. This value is in seconds.Ctrl+X,Y,Enter.reboot and confirm to restart Recalbox.Start > NETWORK OPTIONS. To enable, set the ENABLE WIFI option to On.WPS CONNECTION at the bottom of the menu. This will attempt to find all existing and activated WPS connections around it.
